mkirsch
Apr 27, 2022Nomad II
PastorCharlie wrote:
To find the center of gravity unload the camper onto a good level surface, preferably on concrete, and lower it onto a piece of pipe across the suspected center of gravity. If it balances that is it, if not move the pipe to the lower end until it is balanced. Mark the location.
Not worth the effort. COG simply is not that important. If you stop and actually READ your owner's manual you will see that the COG range in your truck bed is from the front to the back. The picture shows a narrow range, but the numbers are 0" and 78" for a 6-1/2' bed, 0" and 96" for an 8' bed.
This means the COG of the camper can be literally ANYWHERE in the bed according to the manufacturer.
You can have a 5000lb camper with the COG 12" behind the axle, and it will have the same effect as 500lbs on the trailer ball. So again, COG is not all that important.
