nyokie
Sep 15, 2013Explorer
I did the greasing and oiling, and adjusted the bracket under the roof that are connected to the poles, mine only had one screw each, so the roof did hang one side a bit. I since added the missing nuts and bolts,I had to drill thru the side wall. Someone took is coffee break too early at the factory.
Interesting, you mean at the top of the poles inside? I will have to check mine.
