camp-n-family
Feb 21, 2021Explorer
I don’t have experience with that camper but I’m doubtful that it will work with your truck. The manufacturers get away with sales talk like “half ton towable” because they were able to spec 1 truck with the number to do it. In this case it’s likely a bare bones single cab heavy payload truck. This is a rare beast which I suspect you don’t have.
The brochure shows a dry weight of 1910lbs and a gvwr of 2627lbs. Not many 1/2 ton trucks have the payload, or more importantly the axle capacity for that much weight. You still have to add passenger weight onto that. What’s the payload sticker on your door say? Better yet, load your truck with fuel and passengers and go to a scale. Weigh each axle and see what capacity you have left for a camper. You’re going to need close to 3000lbs of capacity on the rear axle. I see a rawr of only 3850lbs listed for non heavy duty option f150. Approximately 2400lbs of that is used up with an empty truck leaving only 1450lbs for camper weight.
