KD4UPL
Feb 21, 2021Explorer II
I had a Palamino 8' pop up TC on a 1996 Dodge 1500 ext. cab 4wd. With just the camper loaded up and the tailgate and spare tire removed I was about 600 pounds over the truck's GVWR. I tried to never put much gear inside at all knowing that I was already so heavy. I was a young single man at the time so I didn't need much gear. Also, it was generally just me in the cab. So, by adding E load range tires, Rancho shocks, and air bags I was able to make it work.
This camper was pretty bare bones; it had no air conditioner, no water heater, no bathroom, only 1 propane tank, and no sewer tanks.
That camper shows an UVW of 1,795. Adding 20 pounds of propane, 15 gallons of water, and a battery will put you at almost 2,000 pounds. I would say loaded with food, clothes, dishes, etc you will be pushing 2,500 pounds.
Weigh your truck's rear axle with you and the wife in the cab, a full fuel tank, and no tailgate. Subtract that weight from the truck's RAWR on the door sticker and see if you have 2,500 pounds left.
