You may find the reason they used something so thin is because the wood needs to to bend in order to get it in place. Even something as thin a 1/4 inch plywood will not have the flexibility to bend.
In my Springdale (former trailer), the water pump was located under the couch. When I winterized, I had to remove the plywood under the cushion. It was screwed down. I unscrewed it and it was paper thin also. This also bothered me, until I tried taking it out. That's when I realized it had to have flexibility to bend into the right position. I debated for a long time about changing it. I never did. And ... I never had a problem with weight on top of the couch either.
If you are really concerned, my thoughts would be to leave the original and just put a second one on top of it. Something very thin. The paneling used in showers would work very well as a second level, and still still have the flexibility you may need to position it in place.
While you are at it... how thin are the sheets under the cushions of your dinette? Mine were made of the same material as the couch.
Edit:
I just looked up your camper model, and the bunks are in the corner. You will not be able to remove or replace a sheet of plywood, get it in there without bending it somehow. BUT!.... if you split it into 2 halves, and then built a reinforcement where the 2 halves (seam) come together, you might have the space to get something heavier in there (in 2 halves). This would work, after looking at some photos of what your camper model looks like.
