Grit_dog
Nov 22, 2018Navigator III
Terryallan wrote:proxim2020 wrote:
I've been in this situation plenty of times in parking lots. In the most extreme case the rear wheels of the truck where no longer touching the ground. Just chock the front wheels of the vehicle and what trailer wheels that you can. This should be plenty enough to prevent a roll away.
One other thing. I wouldn't rely on x-chocks to hold back your trailer as that's not what they are intended for. They are meant to stabilize the tires, not function as a chock. As the tire temperature drops, the tire shrinks, and the x-chocks no longer have the same holding power. Sometimes becoming so loose that they are no longer in contact with the tires. Regular chocks are a much better idea.
You have done it now. I know what you say is true, and the instructions warn about using them for chocks. But those that don't read the instructions, or think they know more than the manufacturer's engineers will come to argue with you.
Or some people just shouldn't use things with so many moving parts.......
