valhalla360
Jun 16, 2017Navigator
Asphalt Concrete doesn't cure like Portland Cement Concrete, so as soon as it's cooled down, it won't get any stronger.
The wider the pads you place it on the better. The problem with plywood is unless you get the very expensive marine plywood, it delaminates quickly if left out in the weather. Thickness does count but your camper isn't that heavy so a foot or two of wood under each leg should be plenty to protect the Asphalt.
