HMS_Beagle
Jun 16, 2017Explorer II
A 3/4" piece of plywood is much floppier than a 3x8. I'd use a 3x8 about 12" long. If you put 1000 lbs in the middle of a piece of 3/4 ply, most of that pressure will end up right under the jack leg. It's better than nothing, but surely not better than a 3x8. A 3" piece of lumber is pretty stiff, and will spread the load somewhat evenly. Let's say 1000 lbs on a 3x3 jack foot is about 100 psi. Spread onto a 12" 3x8, that goes down to 40 PSI - about the same as a sedan tire.
