DutchmenSport
Jun 16, 2017Explorer
We had our driveway resurfaced about 4 weeks ago. The camper sat on the grass for over 2 weeks while they did the work and then we had rain for days, so didn't dare move the camper and run the chance of it getting stuck. Meanwhile, the drive way had a chance to cure a little.
We had a fairly good slope (side to side) made, that it did not have before, so we have better rain water run off away from the house.
Meanwhile, I'm parking on the asphalt now, and yes, using lumber under the tires and jacks. I've always used lumber under the jacks, but now, regardless of which side of the drive way I park on, one side has to be raised to be level. I am using the same blocks under the jacks and put more lumber under the tires. I'm waiting to move the camper once more and then I'll put a larger board under the tires. Meanwhile, I piecemealed this one, so I don't have to take it every time we go, as I keep my stock lumber in the truck all the time. I also painted marks on the drive way so the tires will sit in the same spot, and I know with the boards will be level. If the boards get moved, I can get them back in the same spot.
Yes, the wider foot print of lumber under your tires and jacks, will cause the weight of the camper to spread out more, reducing the risk of new asphalt dimpling under the summer heat! This is one scenario where bigger REALLY is better.
(That green is is grass clippings from mowing)
