Reality_Check
Jun 17, 2017Nomad II
valhalla360 wrote:Reality Check wrote:
Virgin soil 22 psi
Asphalt 29 psi
Compact soil 43-51 psi
Compact gravel 58 psi
If your asphalt is only supporting 29psi, you need to get your money back as you got some faulty product.
Passenger car tires run at 35-40psi. My truck tires go up to 80psi.
Even if you have a real monster of a truck camper, a 2x6 or 2x8 block should be plenty to spread the load out.
PSI ratings for asphalt are all over the board; similar to concrete (not in number, as concrete is so very much higher, but in reference to variances). But I believe that it carries a very low rating for static loads due to the changes caused by temperature. Temporarily, it can carry a very high point load; long term, it cannot.
I have to ask; what does air pressure in a tire have to do with ground pressure? What am I missing there? My truck tires go from 32 to 110, but the load on the ground doesn't change unless the footprint does.
