DutchmenSport
Jun 18, 2017Explorer
Oregun wrote:HMS Beagle wrote:Reality Check wrote:
I have to ask; what does air pressure in a tire have to do with ground pressure? What am I missing there? My truck tires go from 32 to 110, but the load on the ground doesn't change unless the footprint does.
Since the load on the ground is the same, the footprint has to change. If you ignore the stiffness of the tire carcass (which can be considerable), then the PSI in the tire = the PSI on the ground.
This is the very reason you air down the tires for sand.
Having trouble with what you are saying.
If what you are saying is true then removing the camper from the truck would not change the psi on the ground since the psi in the tire did not change.
And for a fully inflated tire the footprint barely changes when you take the camper off.
But taking the camper off should lower the psi on the ground 50 percent or more.
I'm sorry, but I'm having a hard time wrapping my head around this entire concept. Regardless of what the tire pressure is, if the entire weight of the vehicle is 100 pounds, and there are 4 tires, no matter how inflated the tires are, there is going to be 25 pounds pushing toward the ground on each tire (all things being equal).
What does tire pressure have to do with that.
Airing down tires on sand creates more traction, softer tire, bigger foot print as the rubber squishes outward and flattens under the weight of the vehicle. But the weight on those tires touching the ground is the same.
If this is so, then simply airing down your tires on a CAT scale would make the vehicle weights less (or more... however this theory works).
Regardless of pressure in your tires, a 10,000 pound vehicle is going to have 2,500 pounds on each tire (all things being equal). You can't change that. All you can do is spread that weight out over a larger area that touches the ground. That's what the lumber does.
To get back to the OP's original question, yes ... use lumber on the new asphalt. There again, the bigger footprint, the better.
I have a dimple in my new asphalt already, where the car sat. One tire left a dimple. Temperatures hit almost 90 and the asphalt was HOT. Gonna wait for another really hot day and see if I can push it more flat again.
There again, the reason for lumber under the tires is to prevent this type of dimpling. When asphalt is hot from the Summer heat, it gets soft. A heavy load will leave depressions. In a campground you don't notice it simply because it's not YOURS asphalt. But in your own driveway, you notice it!
OP, do all you can to protect the new asphalt. Lumber is so cheap and it provides a LOT of protection to the asphalt. Especially for something that is going to sit for a while not moving. Once it ages, it may firm up, but for now ... use the lumber.
