Bedlam
Jun 19, 2017Moderator
Asphalt is soft and will get impressions if there is too much heat or weight applied. Since you cannot control the exterior temperature, you need to distribute the weight more and/or build up a thicker base of asphalt to handle your desired weight at local temperature.
