pastorbillv
Feb 06, 2017Explorer II
I've got a lot of side slope. I just lower it as low to the ground as possible in the side-to-side level position. Front is always higher. When you get it low-to-the ground, it's not going to move around. I always have those square plastic pieces under the feet to spread the load out (I'm on gravel/dirt). And, when bad weather comes, I often just put the truck under it, so I don't have to be concerned at all.
Good luck!
Bill
Good luck!
Bill
