fallsrider's avatar
fallsrider
Parking Pad
Since we purchased our NTU TT Labor Day weekend, I have been thinking about a "parking pad" of sorts to park the tires on in our back yard. Here's what I came up with this morning.
I purchased 4 pavers 16" x 24" from Lowes and buried them in the ground on top of paver base (sand). Since we have a slope upward toward the rear of the trailer in the area of the axles, I installed 4x4 bump stops to both stop the tires, and prevent mud from washing down onto the pavers. I leveled the pavers from one side to the other so that when I park on the pavers the TT is automatically leveled side to side.
Finished. I could have placed the front paver 2" or 3" further forward, but I was expecting the rear tires to be further back on the rear pavers when against the 4x4s. Oh well, the front tires are still solidly on the pavers.
I am very fortunate that this sewer cleanout (behind the stump) was already in my backyard from when the house was built in '81. It was old cast iron and the cap was rusted on permanently. I dug down, cut it off and installed this PVC cleanout. This cleanout is about 1' behind the rear bumper of the trailer when it is parked. This makes holding tank dumping very easy.
All in all a good day.
  • about the only thing I agree with spike99 is rake up the leaves. I don't agree with the parking on wood or jacking up the frame so the to take the weight off the tires. been reading on this forum for more year than I can remember and none of those suggestion are commonly acceptable.
  • Your pad looks like a good start.
    For improvements:
    - Suggest parking tires on wood.
    - Suggest putting blocks under its frame and lifting it 3" (or so). Thus, taking some weight off its rubber tires and leaf springs. This helps reduce saggy leaf springs (in the long run).
    - Suggest raking the dead leaves away. This help reduce mice.
    For pictures of my previous TT's Pad, surf: http://i178.photobucket.com/albums/w251/Spike99-Pictures/Misc%20Pictures/Front-1copy.jpg
  • Heard of another idea. Take some metal flashing and put it around your tirres to keep the mice from getting in. Mice can't jup up, only down and they can't climb flashing. Just put a slit about 2 in inboard of ea end 1/2 way across and slide the slits together encasing the tires at ground level
  • If possible place plastic between the tires and the concrete under them. Moisture on rv tires stored for longish periods of time causes damage to the rubber.
    Lynxx Leveler blocks would be ideal, or RV Landing gear pads are good too, and come in handy when camping too.
