jimh406
Mar 13, 2023Explorer III
Link to the article... https://www.truckcamperadventure.com/is-the-eagle-cap-1165-too-big-and-heavy-for-a-one-ton-dually/
Fwiw, my 2010 F450 has a 14,500 GVWR from the factory and licensed for 16000 lbs. The newer trucks are not rated higher, so this paragraph is off a bit. I'm under my GVWR, but mine is only 9 1/2 ft double slide. Relative to the larger ones, it's light. :D
Boatycall had a triple slide Eagle Cap on his 2011 F450, or did. I wonder how it's holding up. He was also towing behind it.
But as one Ford F450 owner discovered, a class 4 truck is no panacea when it comes to hauling a heavy camper. Immediately after the rally, this particular owner took his rig, consisting of a 2013 Ford F450 and a 2015 Eagle Cap 1165, to a local CAT Scale to get weighed. He was horrified to learn that his truck was overweight by whopping 2,400 pounds. With a GVWR of only 14,000 pounds and a payload rating of only 5,443 pounds, his truck was woefully overmatched by the 1165. The CAT Scale printout showed 5,160 pounds on the steer axle and 11,280 pounds on the drive axle for a total of 16,440 pounds. Before buying the truck, he was told his F450 could carry “anything” that he wanted and “not to worry.” Obviously, this wasn’t the case with the 1165. When it comes to payload, this illustrates how far today’s trucks have come from trucks that are 10 to 20 year older. Always research before you buy.
