Bedlam
Mar 18, 2023Moderator
StirCrazy wrote:
thats twice I have seen air compressor what are you using that for? I have a little tiny one that weighs about 5 lbs to top up tires if I have to.
how many AH does that 600lbs of AGM give you. I imagin you could save a ton of weight just switching to LFP batteries. water weight is a little over estimated but only by about 60 lbs
so canopy chairs and tables, I am getting the impression you set up in a place and stay there for a while to make the hassel of seting all that up worth it. I only have a old hand crank awning on the once side of my camper so thats what I work with.. I have no storage for anything else haha my two lawn chairs go on the floor under the table and my paddel boards go on the dinet seat when I am traveling.
My tires require over 100 psi, so better quality compressor is required. I use it to seat tires and run air tools for my off-road toys and blow up inflatable rafts. Even the 100% duty cycle 12vdc cannot perform these tasks well due to lack of volume.
The AGM's come used from a server room after 5 years of use, I get another 5 out of them but start seeing degradation and failures after 8 years of service. If they were not free, I would consider alternate batteries but these sit in lower boxes under the flatbed of the truck and connect to the truck, camper and enclosed trailer with heavy gauge wire.
We carry sufficient seating and tables for guests. Rarely do we use park picnic benches. There is some redundancy to what I carry because trips are squeezed in between full time work and wasting time looking for replacements during a trip or canceling a trip is what I try to avoid.
