More2Explore
Dec 29, 2013Explorer
Pass thru window leaking!
On recent trips, the first involving rain and the second involving snow, found the carpet below the pass-thru-window wet. After the second trip on snowy roads with lots of swirling wet snow, water and salt - specially when semi's passed with their own snow storm in tow I found the same wet carpet but with the dirty salt water trail from the window. It was in the window tracks and matched the camper exterior which was covered top to bottom with the dirty salt water road crud residue! Not sure if a seal is missing……seems there should be a seal since there are gaps (can see daylight and obvious water path) at the top and bottom of the trim between the inner and outer window panes.
The camper is a new Wolf Creek 850 and my question is as to whether or not their should be a squeegee type seal between the window panes? Will be calling the dealer again but wanted to see what other Northwood's Mfg. (and other) TC owners have to say about their TC's pass thru window configuration. It'd be nice to just get a new seal shipped and popped in place and not have to make a third long trip to the dealer!
