samuraiowner wrote:
we had the same problem with our sun-lite tc recalked the window and it still leaked so one day while driving in rain stopped got in the camper to check it out and found the problem their is a drain slot cut in the botom of the window frame to drain condensation out of the window frame to the out side of the camper high pressure wind was blowing water through the slot and on to the carpet so i rolled up a paper towel and laid it in the track it keeps the wind from blowing the water out of the track and when enough water builds up in the track it drains out like it is suppose to problem solved.
That's what happened to me, when the roof vent was closed. The problem is compounded because the camper develops a "vacuum" when traveling, so the water actually gets sucked in to the drain holes of the sliding window channel.
Apache Camping Center had heard of it before and called the factory. The response was to leave a vent open slightly when traveling. That worked for me, because I have a roof vent cover on the bathroom vent.
There was so much water building up, that not even a towel placed in the window track would solve the problem.
