CincyGus
Jul 14, 2013Explorer II
bradnailer wrote:Dtaylor wrote:mbopp wrote:
Stackable plastic bins just small enough to fit through the door.
Same here
Same here. All set up gear is on one side then other camping gear on the other.
Same here. If you measure your pass through, you can make the space utilization very effective.
1) Measure your pass through door opening height and width.
2) Measure the inside dimensions of the pass through compartment, again, height and width.
3) Measure the inside length of the pass through compartment (from one door to the other.
What I did was took these measurements to Walmart and went to the isle they had the Sterlight storage tubs. I found a tub that was almost exactly half the width of the pass through compartment and 1/3 the height. It was a little less than half the length. So stacking these three high used up about 25% of the pass through compartment.
I use them for Electrical, plumbing and sewer. They get put on the front half of the road side and I put my lawn mat and easy up canopy in the back half of the road side. Pretty much fills the majority of that half of the pass through with a few other small items tucked in.
The curb side gets my 2 lanterns, propane stove and Weber Q, tools, pancake air compressor, bucket, misc items.
44,071 PostsLatest Activity: Aug 30, 2026
