Walterinmontana
May 29, 2017Explorer
Patching roof on a northern lite.
I'd like to first apologize if this has been discussed. I used the search function to no avail.
I have a 2003 10.2 northern lite. It's a beast. I come from a Four Wheel Camper. I got a great deal on the NL and still am on the fence if I want to sell it or keep it. Regardless, I'd like to eliminate the ac unit on the roof. In my research I have found I can remove the unit and replace it a fantastic fan. Easy enough.....My issue is there is a ~4'x4' ribbed fiberglass panel that the ac unit sits on. Maybe to raise it up? I'd like to remove this ribbed panel and install a fiberglass sheet. I can't find any information on that ribbed panel or what to use to replace it with. All I can really find is "rv fiberglass siding panels". Which I suppose I could use. Does anyone have any info they could share on the thickness I should use? Where to buy? Or any other insight?
I sure do appreciate it.
Walter
Walter
