Community Alumni
Jul 28, 2015The max payload listed inside of the door jamb is the maximum amount of weight you can add to the vehicle (driver, passengers, gear, etc). Before the truck leaves the factory, it's weighed unloaded with all its fluids. To get a payload number they subtract the unloaded weight from the GVWR of the truck. Anything else added to the truck after this point, including the driver, counts against the payload number.
The available payload can actually be much lower than the sticker if you or the dealer installed any options after it left the factory. That's why you should not rely on the sticker. Fill up your truck and get it weighed at a CAT scale. Subtract the weight from the GVWR listed on your sticker. This is your current available payload amount.
The confusion comes from the "Max Tow Capacity" or "Max Tow Rating". This is a rating provided by the manufacturer that tells you the maximum amount of weight that can be pulled by the vehicle. In the Max Tow Capacity, the manufacturer normally has a 150 lbs driver allowance.
