opnspaces
Jul 17, 2021Navigator III
The problem is definitely in the trailer. You're controller didn't just decide to fail between the time you dropped off and picked up the trailer. Hopefully though the problem didn't now damage your Prodigy.
What I would do, but then I always do things a bit differently than most. Disconnect one wheel at a time and carefully do a test pull to see if the problem goes away. If the problem does go away then take it back and tell them which wheel seems to be causing a problem.
