KM_Rolling
Feb 10, 2019Explorer
Wow, been a busy last two weeks.
Here are some more of our mods/accessories-
57. TPMS. After reading so much about blow-outs that folks have, and damage done, I decided it was a must to have a Tire Pressure Monitoring System. Also, wanted it to have a temperature read out.
What's weird is that I've been pulling trailers of different types for over 40 years and never thought about having one. I've only ever had one blow-out in those 40+ years.
It was in July about 15 years ago, in Arizona, pulling an overloaded tandem axle flatbead with a Dodge Cummins powered 2500. The trailer had an F150 on it, along with about 10k lbs of other stuff. It was a non-event. Tire blew, pulled to the side of the road, swapped it out with the spare and was on my way.
BUT, with all the horror stories I read, plus the TT's having a higher profile, I wanted one.
It was a relatively painless install. First up was putting the caps on each of the tires-
They are numbered, so you know which is which on the monitor in the cab-
There is a repeater, to boost the signal between the caps and the monitor in the cab. The repeater/booster is zip tied to the frame, near the batteries, and hooked up to the battery for power. There is a green LED on the booster to let you know that it is receiving power from the battery. (you can see the lit LED at the very left side of the photo below)
Part of the kit is a solar powered (it also has batteries) monitor. I ran it loose on the dash for awhile. After I was comfortable that I liked the system, and I knew where I could put it on the windshield, I installed it in the upper left.
It does not block my view, but it is always there for me to see what the temperature and PSI is of each tire.
It will also beep and flash if any one of the tires have a sudden loss of PSI or gets too hot.
I can attest to this working. In the initial setup you enter the Max PSI of the tire into the monitor. For my tires that is 50 psi. We left on a trip, where I had put all the tires (cold) to 50 psi when the ambient temp was 70 degrees.
One night on the trip we stayed in a rest stop and the temps had dropped to 18 degrees. When we were leaving out in the morning it had warmed up to a whopping 21 degrees. The difference in ambient temps had dropped the psi in the tires to 40 and the monitor was beeping and flashing.
I drove slowly for a few miles, letting the tires warm up. As soon as they all hit 42 psi the beeping and flashing stopped.
Within 30-40 minutes all the tires had warmed up enough that they were at 48-49 psi.
I'm very pleased with the system.
58. Another thing I did for the tires is put Ride-On tire sealant in each tire. Not only does it prevent leaking from small punctures, it also balances the tire.
It was an easy, no mess deal. Unlike slime or other sealants.
59. For a whopping $60 I got a HF motorcycle stand/wheel chock.
It sits on a throw rug on the rubber mat floor and I can drive the bike right on to it.
Since the bike is strapped to the tie-downs in the trailer floor, I have found no need to secure the chock at all.
60. Put some MaxxAir vent covers over our to OEM vents. This allows us to have the vents open while it is raining without it raining INTO the trailer.
We can leave the vents open while gone from the trailer, or while sleeping, and not be concerned about if it will start raining or snowing. Makes life simpler! :)
61. This little "Save-a-Step" adjustable brace makes a very nice improvement. Keeps the step solid and also reduces trailer movement when stepping into the trailer.
62 & 63. To make washing the trailer easier, we got a telescoping brush. It can be used just to dip into a bucket, you can also hook a hose to the end of it.
Makes for quick work of giving the trailer a wash.
Also pictured are wheel chocks that we have for each side of the trailer.
Collapsed-
Extended-
64. Also about washing the trailer. We use the McKee's 37 Sio2 wash. It is very foamy, and also has a small amount of ceramic in it to give some protection and a brighter look.
This has worked very well for us, enhancing the look AND making less stick to the surface, resulting in easier cleaning.
More mods coming soon.
Collapsed-
Extended-
44,071 PostsLatest Activity: Aug 30, 2026
