KM_Rolling
Feb 17, 2019Explorer
GrandpaKip wrote:
I have the same TPMS. Couple things I noticed. Looks like you have rubber valve stems. I had metal stems put in on my new rims and tires. You might want to keep an eye on the stems for cracking around the base from centrifugal force.
Also, as far as I know, you should start out the day with 50# in the tires.
Nice documentation of what you’ve done.
Yes, they are rubber and I am regularly checking them. When I change tires I will be going with metal stems.
Yes, each morning should start out at 50 #'s cold. But I knew that the pressure was only that low because it was so cold and that they would warm up very quickly and the PSI would be good.
If they had not I would have pulled over, broke out the compressor and added some air.
44,071 PostsLatest Activity: Aug 30, 2026
