Slowmover
Jun 08, 2015Explorer
dodge guy wrote:Slowmover wrote:
One ton van. Short rear overhang. Pro Pride hitch. Bilstein shocks plus larger front anti roll bar and a new rear anti roll bar installed. Michelin LTX or Bridgestone Duravis tires on TV.
Excursion worst TV of past quarter century. Serious deficiencies in handling and brakng. See test results for your self. Better choices out there. Steering control really matters.
Your kidding right!? yes the springs are a bit soft, but a set of air bags or different springs (everyone does it with just about any TV) will make it handle very well! My X will haul anything I put into it. I`ve had 4 adults and 3 kids in my X with the trailer hooked up and it tows and handles (and brakes) very well! the X is very underrated from Ford. they put soft springs under it to make the mommy`s like it, that`s why it has a low CCC. give it the proper springs and their is no reason it can`t handle a 10k lb GVWR.
Worst braking. Worst time through the slalom. Etc. Brand new when tested. Read for yourself. Basically, take the worst design of pickup spec and make it worse again. Yes, that makes the worst TV. That's an Excursion.
You want the worst, help yourself
