DWeikert
Aug 21, 2013Explorer II
SS_Sean wrote:DWeikert wrote:SS_Sean wrote:
Lance advertises wet weight....2400#. I guess others advertise dry weight. The tires are D rated (3305# at max psi 65#).
I have a 2008 Lance brochure here that lists the 845 dry weight at 2412 lbs, without any options.
The 3305 lb weight rating is higher than the stock E rated tires were on your truck. Can I ask what size they are? Just curious what size D rated tires have that high a rating.
They're a LT285/75R16... I think factory was a 245 or 265...
Yeah, factory on a GM 2500HD is 245 rated 3042 lbs. Fairly sure that was true in 2001. Your 285's would be okay. But one last question. Do you know the load rating of the wheels? The stock wheels would be a bit narrow for those 285's.
44,071 PostsLatest Activity: Aug 16, 2026
