CO-traveler
Jul 07, 2021Explorer
burningman wrote:
A thing to be thinking about is width.
A pickup dually has a wider rear axle than a cab & chassis dually.
That’s so the inner dual stays where a single wheel would have been, and the pickup box fits without clearance issues with the inside tire against the inside wheelwells.
A pickup dually will give you more space between the duals for your camper, without it having to be completely above the tires.
Good point, thanks. I'm also worried that the C&C frame is higher off the ground than the pickup version and will further increase that top-heavy feeling when turning or cornering.
Like someone else mentioned, I should reach out to SherpTek and see what they recommend.
