ticki2
Jul 09, 2021Explorer
If you take a good look at a c&c truck and take some measurements I think you will find that the axle bump stops will prevent the wheels from ever going above the truck frame so there is really no need for a hump above the flatbed unless you have oversized wheels/tires . You just have to watch the flatbed framing so the wheels have a pocket under the deck . The narrower axle on the c&c is the same width as a srw pickup so you can also convert to srw by removing the dually spacers on the front hubs and use srw wheels .
44,070 PostsLatest Activity: Sep 18, 2026
