Lynnmor
Jul 17, 2014Explorer II
Sheps wrote:Lynnmor wrote:
If the outlet is on the side of the tank that is the problem. The pump will suck air when the water drops to the top of the fitting. Maybe you can tee into the tank drain.
The outlet is on the side at the very upper front road side corner of the tank. That seem like it would require a pickup tube inside the tank that extends to the bottom of the tank.
I like the idea of teeing off of the drain. Just a few fittings and some hose and a plug for the top fitting. I would have to route the hose back up through the floor to the pump. Mabe run hard pipe to above the frame or the floor, then change to the hose. I guess for protection, then seal the new floor entry.
Do you think the pump will pull water this extra distance? It's a Surflo pump I believe.
There is no problem with the pump pulling it. I do think that the pipe at the top is just a vent, don't know. Can you trace that line and see where it goes?
