Bedlam
Oct 10, 2019Moderator
For what you are describing, I would look at starting with a high top canopy with full rear door as your outer shell and build out the inside with sufficient insulation and comforts. A futon style couch on one side that folds out to a queen at night, a catalytic heater with the propane bottle mounted outside in a insulated blanket only when in use, one or two AGM batteries under the futon wired to an inverter and DC-DC charger running to your truck, media center on the front wall or opposite wall from the couch
44,066 PostsLatest Activity: Apr 16, 2026
