path1
Jan 10, 2017Explorer
yankee camper wrote:
Bear with me on my description ... but my interior door leading to the bathroom has a plastic molding around it. It is the type that has a "lip" all the way around it and covers about a 1/2 in perimeter of the entire door minus the bottom. All that being said I hit the molding/casing with my knee and snapped off a 3in. piece it. Does anyone know what this type of casing is actually called and where it can be purchased? Thanks in advance for any help or suggestions for a viable replacement. PS it's only about an 1 1/2 wide.
Any help with links below If so, most any RV dealer should be able to get. Personally I would let your rv dealer order which one he thinks is best, because there are so many sizes and colors. You might get lucky and pull other side if you have one. Maybe skiu number or product number on inside to match up exactly what you need.
http://jrproducts.net/index.php/catalog/?s=rigid+screw+cover&ccm_token=1484093735%3Aabfb92fdf33e4fb44796901d67f020e7
And AP has some.
http://approducts.net/catalog/index.php?main_page=advanced_search_result&search_in_description=1&zenid=37d118ff450a14b55d98f53fd9ff576e&keyword=screw+cover
44,071 PostsLatest Activity: Sep 18, 2026
