missouri_dave's avatar
Nov 19, 2019
Please help me decide on a truck camper
I'm trying to decide between two truck campers from two different manufacturers. One is northern lite and the other is lance. I like the design and construction of the northern lite except it's use of wood in construction but the fewer seams on it is really a great design point I think. The lance has more seams but uses azdel rather than wood in construction and so won't rot or mold even if it does leak. The northern lite has a great floorplan with no slides. The lance model I like has a great floorplan but has a slide. Can anyone give me pros and cons of either one? Anyone gone from one to the other and if so, why?
  • I have owned both Lance 825 and now I own a Northern Lite 811. Both are great campers but the NL has less maintenance and will stay warmer inside in cold weather.
  • Logic says the more exterior seams you have the higher chance of a leak. The Lance has a lot more exterior seams than the NL.
    As for your comment about wood on the NL vs. Azdel on the Lance, it’s really fiberglass vs. Azdel. The wood used on the NL interior is cacooned inside/behind the exterior fiberglass, much the same as any wood used in the interior of the Lance is cacooned inside/behind the Azdel on the Lance. If either camper leaks, there’s going to be potential mold and damage to interior components that are inside the exterior shell of the camper.
    As for a slide vs. a non-slide camper, if you want/need the slide (extra space), then Lance is the way to go. Downsides to slides are 1) limited use of the interior with the slides retracted. 2) Another mechanical device that can break or leak. 3) makes the camper heavier.
