donn0128
Apr 29, 2014Explorer II
Winrerize and dewinterize is fairly simple task. Find the water tank drain qnd open it. Once it is empty close the valve. Add about 1/4cup of bleach qnd fill with water. Turn on the water pump and run a gallon or so thru the lines until the water comes out clearand you have a strong clorene smell. Turn pump off and forgetitfor about 30 minutes. Drain tank, refil with clean water. Repeat as necessary to get good smelling water.
Yes, you need a battery to power everything inside the trailer. A good deep cycle battery. Be sure it is a deep cycle and not a starting battery. There is a difference. You may need help hooking it up if there is not one there already.
Tent trailers do not generally have holding tanks. There should be a cap outside near the sink, unscrew that and connect a drain hose to it. Be awareyou will need a storage tank to hold the waste water to be disposed of properly later.
What the big black hose is? Go0d question. Maybe post a picture.
Gelerally speaking a single propane tank will probsbly last you all season. Cooking takes very littlegas. Furnace will take a lot. Even my 7 gllon tanks dont have gages.
Have fun,practice at home first and dont worry about the family. They will either get on board or sit on their butts at home missing the fun. Their choice
44,059 PostsLatest Activity: Mar 18, 2026
