dodge guy wrote:
I did the same thing to my door over the winter. I cut mine on a radial arm saw. Here is the big secret, you have to turn the blade around so it runs backward!
I found that drilling or cutting any plexiglass, Lexan, or other brittle plastics they tend to crack. Fine tooth, dull cutters work the best because heat is built up which softens the material and almost melts it way through. I found that by dulling drills with concrete first the drills would go through these brittle plastics without cracking.
