enblethen
Nov 10, 2014Nomad
Your converter may not have sufficient capacity to run the slide without the extra power supplied from the battery.
When connected to shore power does any of the 12 volt items work? Water pump, lights, etc?
You may have lost 120 volt shore power
Using slide could have blown fuses in the converter or 12 volt distribution panel.
Slides maybe connected straight to the battery and does not go through 12 volt distribution panel which is very likely.
44,029 PostsLatest Activity: Jan 19, 2025
