bdhoun
Sep 05, 2016Explorer
plumbing leaks in outdoor kitchen
We have a '16 257BHS with an outdoor kitchen. The cabinet that the sink is in slides out about 2 feet. I notice that the flexible hose fittings connecting to the faucet water supplies become loose when sliding in and out due to the flex in the hoses causing rotation of the hose nuts
. Do you think thread locktite might solve the issue with the fittings loosening? Also, the sink drain also has a flexible line going to the abs fittings for the grey water connection. I found the hose had pulled out at the fitting aqain due to the flex when sliding in and out
. I am looking for a more robust connection at both the p-trap and the abs hard line instead of the sliding fitting with lock nut found on normal sink drains.
Any suggestions?
Any suggestions?
