poppin_fresh wrote:
Nothing in these campers is real. It should be pretty easy and fairly inexpensive to replace as the local big-box home improvement store should have a bunch of laminates to replace it with.
It doesn't need to be replaced just adjusted to fit looser. There needs to be space for the flooring to "float" or what happened to you will continue. I would suggest you stop by your local Lowes or Home Depot and speak with someone there, I'm sure they can put you on the road to success.
I have laminate floor in our rig and went through the same problem but after adjusting the flooring it worked out fine.
