bigfootford
Aug 16, 2014Nomad III
Bigfootchevy wrote:
Thanks for all the replys. Today I decided to try a 1 inch sheet of foam instead of plywood.
I believe I will put the foam on the truck bed and the rubber on top of it, with the camper on the rubber mat.
Hopefully this will work.
Paul
Paul, I did the foam thing. What you will find is the camper will compress the foam along the areas where the water tank access plate is attached to the outer perimeter of the camper. All the weight on the front and drivers side of the camper is supported by about 2-3 inches of fiberglass around the perimeter.
That will put stress on the screws and thin fiberglass plate thus elongating the holes and if not corrected will cause the screws etc to become loose and the glass to wear to the point of not being functional.
Along with this issue the camper will finally sit low on the flattened side and will have a tendency to rock.
I did the rubber pad thing. The same issue the camper ate into the pad around the same area I described to you..
Best I have found is the 3/4 plywood cut to fit tight in my bed. 5 individual sections. My camper does not move around. the screws have made impressions in the plywood and you can see that the camper is not scooting around.
Using the plywood you can not make the camper sit in the exact spot each time you unload it so you will have many screw impressions after a couple of years but who cares.
Just my experience.
Jim
