bigfootford
Aug 16, 2014Nomad III
Bigfootchevy wrote:
Thanks Jim:
Just so I clearly understand you put your camper directly on the plywood and not on the rubber mat.
Paul
Correct. The rubber gets drilled by the screw heads and the perimeter of the camper that offers access to the water and holding tanks. The rubber will actually be ate away by the camper moving around.. The plywood does not seem to do that. Had the same Plywood down for about 5 years. It does have several patterns from different positions the camper was lowered in to.
Keep in mind, we have had our camper for 14 years, on 2 trucks... Plywood has been the best medium I have found.
Jim
