Grit_dog
Jan 15, 2018Trailblazer
Well, trailer novice, even though you're clearly not looking for advice, that's what these boards are all about, so please consider the following.
Sales price to dump it and get another trailer....don't trade it, sell it outright.
Fixing the issue....cutting and re welding the hitch is the last thing I'd do unless doing it myself. But, if the trailer has leaf springs, you can run it a little nose high no problem. Which sounds like it will gain you significant ground clearance. If it has torsion axles need to keep it pretty level.
Next best option IMO is to flip or lift the axles. Not typically as big a deal as welding a new tongue on in my book. My 32' snowmachine trailer has the same design for the hitch, but no clearance issue due to it being a deck over axle trailer design. Floor of the trailer is over 2' off the ground, on the level, takes a pretty big dip to bottom it out in back.
