Easy to replace is relative........
Old rusty will be hard to unscrew
Access can be very tight due to location and exhaust venting in the way
Camco makes a wrench for them
The T&P valves are just like ones in home water heaters. Just need to get the correct size (Thread) Sensor probe sits in water.
210*F/150# (Full pop open values)
Weeping can be due to build up on valve disc/seat.....open/snap close couple times with water on and cold. Stand back it will spray :B
Weeping can also be due to loss of air pocket (designed into tank)
As water heats it expands....air controls the increase in pressure due to expansion (air can be compress/water can't)
So if air pocket is gone...water heats/expands....pressure increases...T&P will weep.
Re-establish air pocket------weeping should stop
Turn water off..open faucet...open T&P until water stops flowing...let T&P snap close.....turn on water/close faucet
Simple thermal dynamics
