TxTiger's avatar
TxTiger
Pop-up Truck Campers?
As I look into what I can comfortably put on my truck (figuring about 2,700 lbs ready to camp), the pop-ups appear to have the least weight. I like the Palamino B1250 SB better than most I've looked into, as it has a shower and built in toilet, and other necessities like air conditioning. The camper weighs in at just less than 1,700 lbs dry. It comes well equiped for a pop-up at around $10K. The primary negative is no grey water tank, although it has a 7 gal black water tank.
I have had no experience in/with TC's and would appreciate some feed back from those that have or have had pop-ups. The pro's and con's, so to speak of pop-ups vrs hard sided. Being in Texas, I'm a little concerned about the ability to cool a pop-up with a couple of feet of canvass at the top. This unit has an 11,200 btu unit.
My plan is to use this for extended weekends and trailer the motorcycles when I wouldn't want to hook up the toy hauler. The price on the pop-up is appealing due to my intended use, but if I find this works really well for me I would probably sell the toy hauler and use the TC for all trips. Which brings up the other concern, if I like this mode of camping I will want as much TC and with as many amenities as my truck will carry. On another thread I got good recommendations on light weight hard sided units, like the Travel Lite 890 sbrx. I really like this unit, it weighs in dry at 2,000 lbs, but is quite a bit more expensive equally equipped than the pop-up. The dry weight on the Travel Lite is also probably without air conditioning, so I will pushing my GVWR with a hard side.
I'm sure this just sounds like a lot of "thinking out load", but any advice is appreciated.
  • RoyB's avatar
    RoyB
    Explorer II
    my OFF-ROAD POPUP does not have any GREY WATER TANK as well and we get by just fine catching all the GREY water in two of these AQUA-TAINER 7.5 GAL containers
    I drilled a small hole in the cap and insert a water hose into the container as I use it catching my sink water...
    We usually have to go get fresh water once a day anyway so I carry out my 15GAL of grey water and bring back 10GA of fresh water in my two fresh water containers.
    Having a two wheeled folding cart around helps out alot as well...
    Roy Ken
