kbaum
Mar 26, 2014Explorer
okan-star wrote:
Or better yet , Outfitter has a slide out on the gen compartment for the honda 2000 that I belive can run in place
Not your answer here, if you have a bad back. I had this set-up for four years or so, you still need to start the generator from 4ft off the ground. I was uncomfortable with exhaust fumes by leaving mine on the slide so I ended up setting it away from my Outfitter.
I have seen several Outfitters (specifically Apex models) when visiting the factory with Onan built-in generators, installation looked clean. I believe that set-up might work great for you.
44,066 PostsLatest Activity: Jul 25, 2018
