ktmrfs
May 09, 2018Explorer III
MisterCipher wrote:
I have a 19' Rockwood Eco Pro. I'd like to get a generator for camping off the grid. I want to run the A/C so solar is out as a solution. I'm looking at portable generators as a solution but I don't see any with a 30Amp outlet (even with 1800 watt output). Am I right to conclude that a portable generator is not a solution to run the A/C? The larger generators that do have 30Amp outlet are just too big for me.
Am I reading this right? Or am I missing something?
-Lou
2000ish VA generator is hit and miss, mostly miss, at reliably starting a AC, or keeping it running much above 3000ft altitude.
the micro air easy start will solve the starting issue, but not the altitude issue. with the micro air I can easily start the AC at 5,000ft, with the generator in eco mode, ramps up as the AC starts, but after about 20 minutes overloads. below 3000ft starts and runs it fine.
I'll see this summer if the honda 2200 with an extra 200VA output and a 20% larger engine will solve the altitude problem. the 20% larger engine with a 10% increase in output should result in the ability to provide rated output at a higher altitude than the 2000. But we shall see..
If, along with the micro air easy start, it works at 5-6K ft, it will be for me the ideal solution.
other than that the options are:
1) two generators in parallel
2) a 3000VA or so generator (heavy)
with a supco cap, you may end up being able to start, I wasn't even with the generator not in eco mode.
