SoundGuy
May 10, 2018Explorer
ktmrfs wrote:
the micro air easy start will solve the starting issue, but not the altitude issue. with the micro air I can easily start the AC at 5,000ft, with the generator in eco mode, ramps up as the AC starts, but after about 20 minutes overloads. below 3000ft starts and runs it fine.
I'll see this summer if the honda 2200 with an extra 200VA output and a 20% larger engine will solve the altitude problem. the 20% larger engine with a 10% increase in output should result in the ability to provide rated output at a higher altitude than the 2000. But we shall see..
If, along with the micro air easy start, it works at 5-6K ft, it will be for me the ideal solution.
Waiting for your test results with baited breath :W
