Atlee
May 15, 2018Explorer II
Each person needs to determine their needs, and equip accordingly.
It's obvious the type of camping you do does not require the generators and gas that I do. Which is fine. That's why we have lots of choices. And why trailers run the gauntlet from small pop ups to 35-40 foot fifth wheels.
And my long post was not designed to denigrate any other's opinion. It was supposed to recenter a answer specificly for the OP's original question. I just wanted to give the OP an answer to his question about 30A outlets on portable generators, and give him background on why I chose the generators I did, and why I have generators.
It certainly was not to keep the peeing contest on why or why not a person should carry generators and extra gas, alive. That wasn't the OP's original question.
SoundGuy wrote:Atlee wrote:
My experience is with Honda's.
Next, I needed to get a second 2k generator to run the AC on my TT. Since I already had one Honda, I got a second Honda to twin with the first one.
I also got a 7 gal extended run tank so I have a pretty long run time. Depending on whether I need AC or not, I can almost get through the weekend with only the extended run tank. However, I also carry 3 2.5 gal and 1 2 gal gas cans.
Just an observation that highlights one of many reasons I personally found having a genset more trouble than it was worth. Based on the above information it would seem you carry a considerable amount of gas in order to keep your gensets running for the duration you anticipate ...
7 gals in an extended run tank
9.5 gals in portable gas cans
Total 16.5 US gals or ~ 62.5 litres. :E
If each tank on each of EU2000i genset was also filled that would add an additional .95 gals x 2 = 1.9 gals or 7 litres.
Total 18.4 US gals or nearly 70 litres.
In comparison, my Silverado's gas tank only holds 26 US gals or ~ 98 litres.
Wow, that's a LOT of gas to be dragging around just for running a genset. :E
To the OP ... are you really prepared to drag around quantities of gas like this in your SUV just so you can run A/C in your camper for extended periods of time? :@
