MisterCipher's avatar
MisterCipher
Portable Generator Solutions
I have a 19' Rockwood Eco Pro. I'd like to get a generator for camping off the grid. I want to run the A/C so solar is out as a solution. I'm looking at portable generators as a solution but I don't see any with a 30Amp outlet (even with 1800 watt output). Am I right to conclude that a portable generator is not a solution to run the A/C? The larger generators that do have 30Amp outlet are just too big for me.
Am I reading this right? Or am I missing something?
-Lou
  • Take a look at a Kipor inverter generator. I have the 3000 that I bought in 2009, has worked good for me. I lock it in the bed of my truck at the tail gate. I also have a fiberglass bed lid that closes above it. I point the exhaust out and run it without removing it from the bed. I also have two co2(or whatever bad gas) detectors for safety.
    Kipor IG3000 3000-Watt Generator Inverter
    This runs my 13,00 btu ac, but only on high generator setting. The AC usually will not start if the generator is on ECO mode.
    I also had to add a hard start kit to my AC, to get it to start reliability.
    I very seldom run my AC with this setup, usually I just need to charge the batteries.
    These days, I have 300 watts of solar and do not even need it for charging. One day I might get one of those small 1,000 watt Honda generators also.
    Robert Wynkoop
  • We have the Champion 3100 inverter gen (non electric start version) and it works flawlessly on our Surveyor 245BHS. Runs the A/C with no issues, along with everything else we have thrown at it.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    rbpru wrote:
    You can get a power cord adapter but the ACs usually draw 13 amps plus starting current. I believe most folk go with 2500 to 3000 watts fir AC.
    I am sure the folk will tell you a few different approaches to AC boonedocking.
    Correct; don't even think of running your AC with an 1800 watt genny.
  • You can get a power cord adapter but the ACs usually draw 13 amps plus starting current. I believe most folk go with 2500 to 3000 watts fir AC.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    You don't need a 30 amp receptacle on the genny. Get a 3000 watt Champion inverter genny and buy a 15 to 30 amp adapter from WangMart and you're good to go. That genny can be had for about $899.
