I will try to get this back to your original question, concerning generator's with or without 30A outlet.
The following is my experience using generators for many, many years. First let me state why I use generators a lot. I and a bunch of my friends who also have RV's (Class A, Class C, Travel Trailers, and 5th wheels) tailgate for the entire weekend at Va Tech football games. We park in an open field with no hook ups whatsoever. And in Blacksburg, VA in early September it can get very hot and very humid. Also, in November, it can get very cold. So, AC is useful early in the football season, and electric heater is useful late in the season.
My experience is with Honda's. This is not because I like to waste money, nor because I'm snobbish and want the top of the line stuff. It's simply because when I got my first Honda, an EU2000i, there was only a choice between Honda and Yamaha. Champions and the like were not invented when the world began. They came later after the Hondas were created.
Next, I needed to get a second 2k generator to run the AC on my TT. Since I already had one Honda, I got a second Honda to twin with the first one. The second one is called the EU2000i Companion. It's called this because it's wired with a 30A outlet. So, after they are twinned, either one, or the other, or both can be run, and the TT is plugged into the Companion model. There is one caveat though. The 30A outlet on the Companion isn't an RV style 30A, it's a twist lock version. I just bought a twist lock plug, to RV 30A outlet dog bone. Works perfectly.
I also got a 7 gal extended run tank so I have a pretty long run time. Depending on whether I need AC or not, I can almost get through the weekend with only the extended run tank. However, I also carry 3 2.5 gal and 1 2 gal gas cans. They sit in one of those black cement mixing tubs you can get at Lowe's or Home Depot, should there be a spill. Haven't had one yet in 10's of thousands of miles I've traveled with the trailer.
This set up works great. I don't know about the Champion and other Honda clones simply because they didn't exist when I first needed a relatively quiet inverter style generator. If I just now needed generators, I would definitely be looking at the Champion and other clones.
If you want to run your A/C you will need at the minimum a Honda EU3000i or equivalent. The chief drawback to this generator is the weight. I need to get the generator out of the truck to use with my trailer. I can't leave it in the bed of the truck.
The good thing about the Honda EU2000i, and now EU2200i or it's equivalent, is a little extra power, and individually, they are much lighter. I can get them out of the truck bed.
You can use a portable generator to power your A/C. You just need one or a pair that provides enough power, and that has a 30A outlet. The Honda Companion provides a 30A outlet and I'm pretty sure the Champions and other clones do also.
MisterCipher wrote:
I have a 19' Rockwood Eco Pro. I'd like to get a generator for camping off the grid. I want to run the A/C so solar is out as a solution. I'm looking at portable generators as a solution but I don't see any with a 30Amp outlet (even with 1800 watt output). Am I right to conclude that a portable generator is not a solution to run the A/C? The larger generators that do have 30Amp outlet are just too big for me.
Am I reading this right? Or am I missing something?
-Lou
