Brad_G's avatar
Brad_G
Portable generator
Looking for advice on a portable generator. We just bought a used 24" Class C motorhome that does have an on board generator. I would like to get a portable one for the rare times we tailgate or boondock. My issue is that I want to store in an outside compartment which restricts me to 12" wide to slide in and 17" standing. I just want to be able to run the TV/DVD at night, water pump every once in a while, and plug in a radio and maybe Keurig in the morning. I can do without AC! Can I get by with a 1,000 watt? Also, I need to use a CPAP, I guess I will need to get a cigarette lighter invertor to power that at night, or a separate battery pack like the Duracell 600? I do not want to run a generator while sleeping. Any advice?
  • if it has an onboard generator, why do you want/need another one?
    bumpy
  • Your Cpap is 12 volt the box on your 110 plug converts it to 12 volts get an adapter . how about the microwave ? I would just get a 2200
  • You need to add up all of the watts of the devices you might be using at the same time. Then choose the generator based upon the watts and your size requirements. I'm guessing a 1500 watt might serve you better.
    Once you know the wats you need look through the Camping World, Northern Tools, Sears, Cabellas, Bass Pro Shops or the generator manufacturer websites to locate one that meets your demension requirements.
