eastbaygal123's avatar
Mar 19, 2022
portable grey waste disposal cart
We have a Scamp 16 ft with 2 6 water holding tanks. I would like to be able to drain the grey water occasionally but could only find huge, heavy carts you have to hook up and dump conventionally. Any suggestions? Thanks! Kathy
  • Thank you,ToedToes. I was just wondering about that. I would never dump grey water on the ground, or in a pit toilet. I might be better off getting one of those simple containers that have 2 wheels and a handle and just wheeling it to the dump site.
  • Please check at the campground BEFORE dumping into the toilets to make sure it is OK. Not all pit and/or vault toilets can handle the additional "load".
  • eastbaygal123 wrote:
    This is genius! Of course, a lidded 5 gallon bucket. And I was going to pay $177 for a fancy tote! And since it's gray water only, I was hoping to dump in the toilet at the restroom. Not nearly as obvious.
    Thanks all, for your suggestions. Love this forum.
    How high is your discharge pipe off the ground. Is it higher than a 5 gallon bucket? I guess you could use a short garden hose to fill bucket?
    A proper waste tote will always be easier, but not cheaper than a 5 gallon bucket
  • This is genius! Of course, a lidded 5 gallon bucket. And I was going to pay $177 for a fancy tote! And since it's gray water only, I was hoping to dump in the toilet at the restroom. Not nearly as obvious.
  • I got this Tote and use a folding hand truck with some bungie cords to walk it to an appropriate place to dump the gray water. If it requires driving, the filled tote is not too heavy to lift into a vehicle.
  • Since the gray tank only holds 6 gallons, a twenty gallon tank should be more than sufficient. If you only put 6 in it, it should be very easy to handle b
